I decided to make my own air/oil separator. This is not a big deal, many have done this before and you can find various different designs on the net. Mine is just a 2" PVC tube with some green scotch-brite material stuffed inside, an inlet on top, outlet on the side and drain plug on the bottom. Simple. I painted it black so it looks a bit more "professional".
