Michaels Sonex #145 log
Date:  12-20-2014
Number of Hours:  1.00
Brief Description:  Misc FWF work
Now that I'm done with the canopy it's time to get back to the firewall forwar, there are a few things that still need to be finished there.
First of all I needed to add some holes in the rear baffle fo the breather tube and ignition leads, so I marked the position of the holes, removed the baffle, selected the correct size grommets, drilled the holes and installed the baffle again.
The breather tube itself also still needed to be made so I did that next.
I will use an aluminium tube to go from the engine through the baffle, then a rubber heater hose to connect it to the oil separator, which I still need to make and install. That's next.
