Brief Description: Installing the air/oil separator
I attached the air/oil separator to the firewall using hose clamps, a piece of 0.025" aluminium and 2 3/16" rivets. The pictures pretty much show what I've done. A rubber heater hose connects the aluminium tube coming from the engine case to the air/oil separator. Now I only need to make connect the outlet which will come out of the bottom of the cowl.
