I finished installing the carb today, this requires disassembly of the carb to install the throttle cable. but first I had to trim and fit the throttle & mixture cable housing. The carb was re-assembled mixture cable was then installed and the carb attached in place with hose clamps and lockwire as per the installation manual.
