Building Integrity
Date:  4-29-2014
Manual Reference:  ch 9
Brief Description:  Brake line Bid and pee tube exit
Pic #1 shows that I laid down aluminum foil tape in prep for the fairing skirt. However, before laying this up I need to hardmount the fairings onto the gear legs and I can't do that until I can verify the angles of the gear leg fairings. SO, I can't do all that until the brake lines and pee tube are under cured strips of BID tape. I laid them up in 3 places along the legs. After cure I'll get both fairings microed in place in prep for the skirts. getting closer to seeing the belly of this airplane in primer :0
The pee tube will exit through a 90 degree aluminum bend that may or may not be flared at the end. It will depend on the amount "suction" this provides. Lowest drag is the goal.
bid over lines
bid over lines
pee tube exit
pee tube exit
