Zenith CruZer & Sonex Logs
Sonex
14 - Cowling
5-22-2011
SNX-P13
Riveting Cowl Hinges / Dimple & Rivet Fuel Door
Just tedium tonight.
Riveted top & bottom centerlines, side, and bottom aft hinges to each cowl half. All hinges have flush rivets. Will look good once painted.
Drilled fuel filler door for the hinge; dimpled rivet holes in door and hinge; riveted with flush rivets.
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
