Zenith CruZer & Sonex Logs
Sonex
07 - Fwd Fuselage
9-19-2009
SNX-F10
Fwd Fuse Detail Parts
Spent the limited time today fabricating channel pieces for the aft portion of the fwd fuselage (the under-seat supports).
Cut the seat back hinge to length, cut out the 2 center lugs, and drilled pilot holes 1/4" from the edge.
Fabricated SNX-F10-10 R/L, the center support section (SNX-F10-12), and the right section of SNX-F10-13R (still have to do -L).
SNX-F10-10R/L, SNX-F10-13R, SNX-F10-12
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
