Sonex 1170
Date:  6-5-2009
Number of Hours:  1.20
Manual Reference:  SNX-F19
Brief Description:  Riveting Turtledeck
Riveted all external former locations and the upper longeron runs.
ALMOST done; still have to place the AN3 hardware for the vertical surface of the upper splice plates, then rivet the bottom of the crosstie box.
Although SNX-F18 says it's OK to rivet the bottom skin on now, I'm gonna hold off. I'll want to run some antenna wire (maybe) and bolt the seatbelts in place before then.
Riveted Aft Fuse (well, just a bit more)
Aft Quarter View
Aft Quarter View
From the inside
From the inside
