Zenith CruZer & Sonex Logs
Sonex
05 - Aft Fuselage
5-18-2009
SNX-F21
Finished SNX-F21
FINALLY finished SNX-F21, the lower part of the aft fuselage.
Riveted #2 upper crosstie, #1 vertical channels-to-crosstie box & lower crosstie, and upper splice plates to longerons and crosstie box.
Next up: Turtledeck Dug around; found the splice plates, forward deck former plates, and stock to make the channel and clips.
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
