Zenith CruZer & Sonex Logs
Sonex
05 - Aft Fuselage
4-25-2009
SNX-F25
Fit / Drill new Lower Splice Plates
After chamfering the edges last time, tonight was the time to mate them and fit to the longerons.
Up-drilled two of the holes on each assembly to 3/16". These are the only holes to be taken up to final size at this point in the assembly.
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
