Zenith CruZer & Sonex Logs
Sonex
05 - Aft Fuselage
4-19-2009
SNX-F21
Finalized Detail Parts / Start Fuse Alignment
Finished detail parts. Trimmed SNX-F24-06 / -07 (cut to length last night). Fabricated SNX-F24-09 (lower cross tie #5).
Riveted detail parts including shear web, left / right seat belt attachment, and cross tie box #1.
Fabricated spacing jig for fuselage alignment by drilling and cleco'ing two 90 deg squares together.
Set up fuse side panels (upside down) and clamped lower cross ties into position (very rough spacing).
Disassembled lower vertical tail channel from the vertical tail assy for use in setting the aft spacing (see pic 3 below).
Riveted Detail Parts (shear web / seat belt mounts)
Inner Aft Fuse (upside down)
From the tail end (upside down)
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
