Sonex 1170
Date:  4-12-2009
Number of Hours:  3.30
Manual Reference:  SNX-F22/23/24
Brief Description:  Misc Aft Fuse Part / SubAssy Fab
Spent time making various parts and subassemblies in preparation for SNX-F21 aft fuse assy.
Completed SNX-F22-02 Shear Web Assy. This required fabrication of a front angle from 2x2 angle stock and drillling holes to match the kit-supplied shear web. Also attached SNX-F22-05 rear web angle; required drilling 3 holes in shear web to match the angle piece.
SNX-F24-12 / -13 are shipped in the kit identical. -13 has 3 more holes on each end. These form the top and bottom of the front crosstie box that will be assembled shortly. Used the -12 parts to match the hole spacing in -13.
Fabricated SNX-F23-09 and -11, the forward and aft support channel. These have a 1 1/8" hole with a bushing in each one which will support the elevator control rod.
Fabricated SNX-F23-12 support clips (2). These were cut from 2x2 angle stock, then down to 13/16 on each leg. 5 rivet holes are drilled in each leg, and the angle is reduced from 90 degrees to 80 degrees. Used the vise to squeeze them tighter.
Marked up SNX-F23-02 bulkhead, and drilled pilot holes for the three holesaw cuts. Two 1.5" holes are spaced 5.5" apart; these will have the center material removed to form a large oblong cut.
