Riveted all sub-components for the left wing aileron bellcrank that fits to aft rib #9. Had to re-do 2 rivets near the pivot side of the bellcrank itself as the rivets failed to seat correctly.
Decided to go ahead and rivet the skin attachment clips to the vertical stiffener pieces; some builders wait until the skin is in position, but I worked up a jig with a piece of skin material that allowed me to get very close if not spot-on with the fit. Worked well on the right wing, so I have high hopes for the left as well.
