Sonex 1170
Date:  11-17-2008
Number of Hours:  2.30
Manual Reference:  SNX-W07
Brief Description:  Riveting Right Wing Upper Aft Skin
Bolted the long and short aileron control pushrods to the aileron bellcrank. Will torque and install cotter pins when I do the bottom skin.
Re-checked to ensure the wing was square and level, even though the skin would determine the final alignment.
Positioned and cleco'd the upper aft skin into place. Riveted all (?) 264 or so CCP-42 rivets. Main spar row of rivets are not installed until the leading edge skin is installed.
