Zenith CruZer & Sonex Logs
Sonex
13 - Engine
7-20-2011
SNX-P30
Engine Baffle Work
Drilled all 4 of the angle attach pieces for the side baffles.
Finessed the fit of the right side baffles. Determined ultimate placement.
Drilled the aft baffle holes thru the engine case; installed self-tapping screws to hold the baffle against the case firmly.
Re-bent several baffle pieces in a trial and error method to get a good fit.
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
