Zenith CruZer & Sonex Logs
Date: 2-1-2012
Number of Hours: 1.00
Manual Reference: n/a
Brief Description: Cowl Paint, N-Numbers, Vertical Tip Paint
Repainted the lower surface of the left cowl; gave it a 2nd coat yesterday, but somehow forgot one surface.
Shot a 2nd clearcoat layer on the right cowl. Just need to let it set for a few days, wet-sand, then buff with compound.
Applied N-numbers. I've had them awhile, but *legally* you're not supposed to apply them to an airplane until you receive the registration certificate from the FAA. I rec'd mine yesterday, so the numbers went on today. Nice job by Aircraft Engravers.
Masked the vertical and horizontal fins. Cleaned the vertical tip with MEK & alcohol, then went over it with a tack cloth. Shot a good, no-run primer coat. Waited 1/2 hour, then applied the first color coat. Waited another 15 mins and shot a second colorcoat.
Will just need to let it dry for a few days, sand, then start the clear-coat.
N-numbers applied
Masked & Primed
Painted
