Brief Description: Final Color Coat Wingtips / Sand & Prime Wheelpant
Started off by performing a final sanding cleanup of both wingtips. Re-shot with a light color coat. I'm satisfied with the results; will shoot some clearcoat tomorrow if weather holds.
Next, spent a lot of time sanding the seam areas of both wheelpants. I was very impressed with the sand-ability of this new 2-part putty I used (Metal Putty). Had enough primer to shoot one of the pants.
Lastly, spent a lot of time sanding the putty off of the rivet lines on the left cowl half. Will need to apply a light skim coat on some of the rivets; will know better when I finish sanding.
Sanded filler
Initial Primer Coat
Color Coat on Tip; Paint was dry before dust landed
