Zenith CruZer & Sonex Logs
Sonex
SNX-W12
Completed Left Rear Spar
Quick wrap-up of the left rear spar.
Up-drilled all rivet holes to #30 (well, almost all. you're supposed to leave the holes that will eventually mount the aft ribs empty for now).
Removed all parts, deburred, then cleco'd into place.
Riveted with CCP-44's, except for the two CCP-46 rivets required for the root rib attach angle.
Completed rear spar pair
overall view of rear spars
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
