Zenith CruZer & Sonex Logs
Date:  11-30-2008
Number of Hours:  3.30
Manual Reference:  SNX-W07
Brief Description:  Right Wing Lower Aft Skin Riveted
Wrapped up the deburring / cleaning / FOD check, etc. in preparation for riveting the right wing lower aft skin.
Placed the wing box back onto the table; re-checked level & square - spot on. Placed the skin into position; cleco'd every other hole.
Riveted all CCP-42 rivets. Root rib not riveted (have to wait for wing rigging & root doubler trimming), and main spar not riveted (have to have the leading edge skin in place).
Ran pitot/static tubing, fastened aileron bellcrank inspection plate (SNX-W18-02) into place using AN530-4-6 self tapping screws.
Leading Edge View, with Pitot / Static Tubing
Inboard View Showing Riveted Skin
