Zenith CruZer & Sonex Logs
Sonex
SNX-W15
Forward Rib Trimming
Trimmed forward ribs 1-4 (2 each) to fit the main spar caps.
Also trimmed the SNX-W15-06 gussets after receiving the OK from Kerry @ Sonex that the rivet distance from the edge would not cause problems.
Forward Ribs 1-4
Trimmed Gusset on the Left (qty 8)
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
