Zenith CruZer & Sonex Logs
Date:  10-19-2011
Number of Hours:  1.20
Manual Reference:  SNX-E01
Brief Description:  Fuel Tank Calibration
I've had the crud for the past 4 days; aches, pains, and congestion. Felt like crud as well.
Started fuel tank calibration today. Obtained 2 gals of 100LL from the neighborhood airport and loaded into tank. Fortunately, no leaks from the sender or fuel outlet. The calibration instructions by both Sonex and MGL are a bit confusing. I think I finally have it set up "OK". Will know for sure as fuel added. (Kerry says only 2 gals really needed, so that's all I have on hand.)
Made up a dowel dip-stick; have notched it for the 2 gallon mark; will add new notches as fuel added later.
