Zenith CruZer & Sonex Logs
Sonex
SNX-C01
Install Trim Tab Actuator Cable / Drill Sticks
Installed the cable core; trimmed the cable housing to length at the trim adjust lever in the cockpit.
Bent the ""Z"" in the end of the cable as per plans; inserted into the trim tab, and secured with cable clamps (visible in 2nd picture below).
Drilled the control sticks at the bottom to allow PTT & memory swap button wiring to be installed. Insulated with rubber grommets.
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
