Brief Description: Detail parts for aft portion of fwd fuse
Cut elevator control rod notch, bent the end tabs down 4 deg, and drilled pilot holes on the ends of SNX-F10-01 angle (aka SNX-C06-05 for the lowered seat option).
Located pivot bushings for the idler pivot.
Drilled out holes in idler pulley to 1/4" and 3/16".
Cut 032 stock for -08 clips, and SNX-F10-07-R/-L clips. Fabricated clips per plans.
Cut 032 stock and fabbed 2 SNX-F10-11 clips; bent and drilled pilot holes
Fab’d SNX-F10-13L seat belt attach channel.
Drilled holes in bent flange of previously made SNX-F10-13R seat belt attach channel.
Cut SNX-F10-20 spacer block from 3/16” stock. This goes between the idler pivot halves to provide spacing for the pivot.
