Drilled the two missing holes in SNX-F16-04, the aft support angle that goes on the tunnel zee. Had advised Sonex of this, and they said to just go ahead and drill the holes. Countersunk using the 120 deg countersink. Drilled corresponding holes in the aft tunnel zee and dimpled those holes. Also countersunk 3 holes on each end of the support angle to 100 deg. to hold driven rivets that are applied later on.
Deburred other remaining holes on SNX-F16-04.
Countersunk the left aft wing attach angle to match the aft tunnel zee assembly.
