Zenith CruZer & Sonex Logs
Sonex
SNX-F19
Riveted Internals
Did all the hard riveting tonight - the inside of the aft fuselage.
Riveted all formers to lower vertical channels as well as the upper splice channel.
This was a real bear due to the heat / humidity / cramped spaces. Had to drill out and replace about 8 rivets because they failed the fingernail test.
All that's remaining is to rivet the outside formers and upper longerons and then it's on to the forward fuse.
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
