Zenith CruZer & Sonex Logs
Date:  3-15-2009
Number of Hours:  3.00
Manual Reference:  SNX-W03
Brief Description:  Completed Right Aileron
Plans sheet SNX-W03 finished!
Removed protective film from hinge and rivet areas; disassembled completely.
Riveted counterweight assembly.
Deburred ribs and skin, inside and out.
Re-assembled tip rib into position. Had marked some overhang last night; used the Andy snips and a file to smooth out and level the offending edges. Took 3 shots at making it as close to right as could be.
Reassembled all, riveted. Had to drill out and replace two rivets near the counterweight arms.
Really want to start on the aft fuselage, just to do something not wing related. But, I may fit the fiberglass wingtips and mount the position lights/strobes just to be done with it.
Counterweight Assy
Counterweight Assy
Me Deburring the Skin
Finished and (Temporarily) Mounted
