Zenith CruZer & Sonex Logs
Date: 2-23-2009
Number of Hours: 1.70
Manual Reference: SNX-W03
Brief Description: Mark / Drill Left Aileron
Spent some quality time in the boonies of Kansas the past few days; very relaxing. Unfortunately, nothing got done on the Sonex either, but all in all a good attitude adjustment.
Last time, marked the upper/lower skins for rivet placement. Tonight, marked the hinge surface (call it the vertical?) for the 4 rivets of each rib.
Positioned the 3 ribs, and placed an initial pilot hole thru the vertical surface and into the ribs. Then, pilot drilled the other vertical surface holes. Next, pilot drilled the lower skin surface, followed by the upper skin surface.
Still have to pilot drill the hinge, and the infamous tip rib, then up-drill, deburr, and rivet.
Drilled / Cleco'd Left Skin
Outboard End, Cleco'd Left Skin
