Zenith CruZer & Sonex Logs
Date:  5-22-2008
Number of Hours:  1.10
Manual Reference:  SNX-T07
Brief Description:  Horiz Stab Misc
Fabricated SNX-T07-07 cable clip that will attach to the root rib once mounted to the elevator skin. Did additional cleanup work adjusting the vertical stabilizer fiberglass tip because I felt it still was not straight enough. In checking other stuff, discovered that the right elevator skin I cut this past weekend ended up about 1/4" too short - ARGHHhhhhhhhhh. New skin is $65 from Sonex; will have to bite the bullet and get a new one.
