Brief Description: Cutting Lightening Holes in rear wing ribs
I suoopse I could have done it more production like, but one hole at a time is OK for me. Have 4 more ribs to cut the 95mm hole then open it up to 115mm for the others.
The cutter will sometimes catch, that's when you want to back off on the pressure and start cutting again. Rotate the motor around to get all the way around the hole. The dimensions are holding good.
