Michaels Sonex #145 log
Date:  9-23-2013
Manual Reference:  W07
Brief Description:  Preparing and priming
I couldn't continue dimpling the forward skins as I've lost my dimple die, luckely another Aussie builder has mailed me his which I should have by tomorrow so I won;t need to wait till the ones I ordered from the U.S. arrive to continue dimpling.
For tonight I had to find something else to do though, I decided to prepare the 2 aft skins, and pitot static support plates for priming. After that was done there was no reason not to coninue so I primed the skins and plates.
As you can see from the pictures I went back to using the grey etch primer. I just struggle with the green EcoPrime too much.
This stuff is much easier to apply and is also much more durable, the EcoPrime is very fragile and scratches easily. I will use it just one more time to go over my skeleton again because I made a lot of scratches installing the skins, also that will save me from having to spot prime the holes I drilled to attach the skins.
