I made the slot for the canopy side handle in the canopy today. With the canopy on the correct position was marked, the canopy was then taken off. I started by drilling a hole at either end of the slot, then connecting the holes using my Dremel tool with cut-off wheel. Finally finished the hole using a file, followed by 80, 120, 180 and then 220 grit sandpaper.
