The side baffles from the AeroVee baffle kit went on fine, as did the corner baffles, but the left and right front baffles needed modification again. The cylinders are longer than the AeroVee's and the shape is different so I had to make new baffles to fit the size & shape. The first picture shows the AeroVee baffles in place, you can clearly see the difference in size & shape. The second and third pictures show the new modified baffles installed.
