Brief Description: Stick to idler pushrod and cover
I'm pretty much ready to move on to the next phase in the project (the engine) there was one final thing I wanted to get done first, installing the stick to idler pushrod and making and installing the pushrod cover. Making the cover was easy but installing it a bit more complex, the anchor nuts used to secure it would have been a lot easier to install before the center channels were attached to the fuselage floor. Anyway, I got it done. Installing the pushrod itself was a piece of cake, However I found out I had the rod that connects the control 2 sticks installed upside down which meant it was interfering with the stick to idler pushrod when pulling the stick back, so I had to remove, flip and reinstall that one too.
