Brief Description: Cleaningand testing the fuel tank
I cleaned the tank today, quite a bit of debris from the cutting, & sanding was still in the tank, the tank is cleaned with fuel. Afterwards I plugged all the fittings and put 20l of clean fuel in the tank to test for leaks, I put the tank in various positions to test every fitting and left it there for a while. No leaks.
