I started working on the electrics today (finally). The first thing I decided to do was install my AeroFlash anti-collision light. Since I did not bother with wingtip strobes, installing one of these on the belly of the aircraft is a good alternative. I copied the idea from Jim Lewis (it's not the first idea I copied from Jim). The AeroFlash unit comes with a white dome normally but they offer red replacement ones as well, which is what I'm installing. Installation was too easy 4 rivets to hold the light to the belly of the aircraft, 4 AN525-10R8 bolts hold the power unit in place under the seat, done.
