Not a good night tonight, I started working on the rudder pedal pivot block assemblies, in short, one turned out ok but the second did not,one of the holes for the an3 bolts is about 1-2mm out of position, the phenolic block must have moved when drilling. Anyway, this means I need to order a new piece of phenolic and can't continue working on the rudder pedal installation until I get it. That will be a couple of weeks I'm affraid, I'll have to find something else to work on for now.
