Continued to work on routing and connecting the oil and radiator hoses. Installed the $70 fitting in the bottom of the crankcase for the oil return hose. Made a couple of the battery/starter wires using MS tefzel wire as I try not to use the automotive wires supplied by Rans. Corrected a mistake I made in the installation of the muffler mounts.
