Mounted the oil cooler and radiator. Continued routing the oil lines and radiator hoses. I was not happy with the lengths of a couple of the oil hoses. We shortened the line from the oil pump to the cooler by about an inch and a half. Fits much better now. Reclocked the fitting at the end of the oil hose from the engine crankcase to the oil tank. Waiting for the fitting to hook it up. The radiator hose routing was OK but I think I will add a rubber elbow going into the expansion tank at the top of theengine for a smoother transition behind the engine.
