Garys RV-7 Builders Log
Date:  7-10-2011
Number of Hours:  3.00
Manual Reference:  7-11
Brief Description:  Fabbed hinge pin retainer, installed flap
I match drilled the right flap hinge and deburred first thing today. Next I fabbed a retainer to secure the hinge pins. I stole the design from a guy on VAF.net. I cut one hinge eyelet in the middle of the wing side of the hinge and two eyelets off the flap side. Next, I cut and bent to final shape both sides of the hinge pins and installed the flap and secured them. It turned out really good. Next session I will install the same retainer in the left wing.
View from bottom of wing.....
Hinge pin retainer
Hinge pin retainer
Aileron/Flap gap slightly over 1/4
Aileron/Flap gap slightly over 1/4"
