Brief Description: Installed pitot tubing to bay location
Tonight I removed the L wing outboard bottom skin. I then used a step bit to enlarge a hole in the wing rib by the pitot tube mount and installed (2) snap busings. I then uncoiled some extra tubing and pulled it through the bushings to the bay the pitot will be mounted in.
