Garys RV-7 Builders Log
Date:  5-26-2011
Number of Hours:  1.50
Manual Reference:  7-11
Brief Description:  Clecoed L wing bottom skins and match drilled to h
I clecoed the L wing bottom skins on the ribs and match drilled them to the flap hinge and flap brace. I should have had the skins on when I match drilled the hinge last session which did affect the fore and aft location of the flap in relationship to the trailing edge of the aileron. The flap is now forward of the aileron 1/16" but it is purely a cosmetic issue.
Bottom skins clecoed, aileron aligned
Flap/aileron relationship
Flap clecoed in position
