The first thing I did tonight was to remove the bottom bolt in each aileron bracket so I could access the spar outside rivets. I used new nyloc nuts and tightened them to 25 in-lbs.
Next, I finished the pulled rivets on both ailerons which completes them. It is nice to have these finally done and I am happy with how they turned out. It took a month and about thirty hours to finish both ailerons. On to the flaps.....
Nut that was removed to allowing setting rivet above.
