Garys RV-7 Builders Log
Date:  4-6-2011
Number of Hours:  2.50
Manual Reference:  7-10
Brief Description:  Finished riveting aileron top skins to spar
Tonight I finished riveting the top aileron skins with Coltens help. I then riveted the top of the outside ribs. Next, I bolted on the aileron brackets and torqued the AN3-4 nyloc nuts to 25 in-lbs and then clecoed the bottom skins in place so they are ready to rivet. Diane worked late and hung out in the shop to have a couple beers when she got home.
Right aileron inboard bracket bolted in place
Aileron top and bottom view
Leading edge and bottom skins ready to rivet
