Colten helped me dimple the aileron rib trailing edge holes with the bench mounted dimple die. He held the ribs while I hit the die with a dead blow hammer. The dimples turned out nice and look the same as with the Big D.
Next, I cleaned all of the aileron parts with MEK and then primed everthing with Duplicolor self etching primer. I will be able to start riveting the ailerons together next session.
