Garys RV-7 Builders Log
Date:  12-5-2010
Number of Hours:  1.50
Manual Reference:  7-9
Brief Description:  Started riveting leading edge to main spar
Colten helped me start riveting the leading edge to the spar. It was a real struggle, but Colten hung in there and we got nine rivets installed. I will need to order some pulled rivets as I will not be able to reach in and buck all of them. Colten ran the rivet gun and I bucked. The ones that we got done turned out pretty well.
L leading edge on spar
Offset rivet set, ground on left side
