Garys RV-7 Builders Log
Date:  11-24-2010
Number of Hours:  1.00
Brief Description:  Installed some hangers for wing conduit.
After completing the fuel tank leak testing, Colten and I worked on the conduit hangers. Colten used the ultrasonic cutter and cut off one of the mounting tabs from each hanger. We then removed the wire ties in each rib and then pop riveted the hangers in place after slipping it over the conduit. We were only able to complete the left wing. I like this set up and think it will work well.
pipe hanger holding conduit
