Brief Description: Re-closed elevator trim tab system
No time for building tonight, but I did heat shrink the new connector in the elevator trim tab system. This was mainly so I could replace the access cover and get it back to its storage location (of honor) above the entertainment center in our master bedroom. The heat shrink, as you can see, is primarily to hold the two halves of the modified D-Sub connectors together.
