Larry Winger's 601XL Project
Date: 3-12-2007
Number of Hours: 6.50
Manual Reference: 6W4
Brief Description: Center spar ready to prime and rivet
My dilemna of how to precisely center and align the center upright supports was solved by making my blanks about two inches longer than needed. I then cut a piece of sheet aluminum to be 70mm wide and the length of my extruded angle pieces. I then carefully measured and blind riveted the angles to the aluminum sheet. This held things exactly 70mm apart. I was then able to move that around, as a unit, until it was precisely where I wanted it. I taped and clamped it down, flipped the piece over, and back drilled. Voila! After that, I marked the top and bottom lines, removed the backing sheet, then cut and sanded the angled ends. I can't say that my track record was as good for the additional uprights installed to accomodate my dual controls. My perfectionistic tendencies got the better of me, and I probably made 8 uprights and drilled them in place, before getting the two that I wanted. Finally, I assembled the unit, measured for the 45mm cutouts on the top flange and completed that process. Tomorrow I plan to do some practice riveting, then clean and prime the spar parts and hopefully get this completed by this time tomorrow.
The front - complete with upright support for dual controls
The back side - showing 45mm cutouts on top flange
Side view of the front of the center spar
