Building Integrity
Date:  7-7-2014
Number of Hours:  1.00
Manual Reference:  ch 13
Brief Description:  Nose hatch finished and installed
The nose hatch was lined in 1/16" weather seal (my favorite stuff) and installed for good. However, as luck always has it, the last screw to be screwed in broke the threaded hardpoint lose and pulled it out of the nose. GAH! Easy fix. I cleared out the cavity in the nose, made a new threaded hardpoint, stuffed the hole with flox, then pressed it into place with the hatch installed. It will cure in the correct position and should no longer be an issue.
following the edge line and contours.
Hatch is in and the fit is tight and flush! PERFECTION!
