Brief Description: Accessory panel install and spar closeout
I installed both Accessory panels and then removed the peel ply from last nights 1 ply of glass laid over the spar end holes. The holes are suppose to remain per plans, however I've routed my wires and cables differently in order to keep moisture out of the spar and protecting the wing bolts from corrosion.
